Venture Beats: GameShell DIY handheld is a great way to play retro games
Written by JEFF GRUBB
The original article is: https://venturebeat.com/2019/01/10/gameshell-review/
Ever since the Nintendo Switch came into my life, I’ve played a lot more games. You would think I was already playing them all the time due to my job. And sure, I played a lot. But I spend most days writing about them. And in the evening, I dislike hiding away on my PC in the office or taking over the television to make everyone watch me get frustrated with a race in Forza. The Switch and The Legend of Zelda: Breath of the Wild made me realize that I am happy with handheld gaming. And now, all I can think about is getting more handheld devices to have access to games beyond the Nintendo eShop.
That’s where the GameShell from ClockworkPi comes in.
The GameShell is a do-it-yourself modular handheld kit that comes with everything you need to piece together your own portable console for $159 ($139 for students). ClockworkPi has built a Linux-based device that runs on a RetroPi-style micro computer. It comes with a screen, the buttons, a case, and everything elfffffffffffse you need to assemble your own Game Boy-style device. And you do have to assemble it yourself.
But is that process friendly, and what about the quality of the end product? Well, the GameShell has a lot to love.
What you’ll like
Easy to put together
The GameShell comes as a collection of plastic parts and circuit boards (PCBs) that you piece together. This process is painless. I would expect that most teenagers would have little trouble with the assembly. And even most younger children could probably get through it with some supervision.
You’ll just want to make sure that you are cautious when popping out the plastic parts and handling the PCBs. The only issues I had were with excess plastic around certain parts that I had to cut away using a tool. A razor blade and wire cutters are all you really need.
Plugging it into and arranging it in the GameShell, however, doesn’t require any tools. You won’t find any screws or bolts. The PCBs and buttons snap into the plastic, and then the plastic parts connect together and hold everything into place.
And surprisingly, the result doesn’t feel cheap or like it’s going to fall apart.
Nice software
One of the best aspects of the GameShell is its operating system. It runs Clockwork OS, which includes emulators for GameBoy Advance and indie game CaveStory.
The menus are swift and simple to navigate. And the system loads content relatively quickly. It also comes with RetroArch, which is a frontend for emulators. RetroArch makes it simple to add support for other platforms as long as you set up an internet connection.
It’s easy to add more apps to the GameShell. If you connect it to Wi-Fi, you can send files over your network from PC. This makes it easy to add other emulators or even your own software. The ClockworkPi website also has great forums with lots of tutorials on how to add specific apps that are easy to follow.
What you won’t like
The screen is underwhelming
After an extended test period with the GameShell, I’m really happy with it. But I would like a sharper screen. The one that comes with the device is OK, but the resolution is low at 320-by-240. Even on such a tiny screen, that resolution looks fuzzy. I would love to have the option to upgrade to 720p.
Beyond the resolution though, the screen does have a bit of ghosting. The LCD display clearly struggles to shift from light to dark and dark to light. And you will notice moving images leaving trails as the pixels try to keep up with the on-screen action.
Conclusion
The GameShell is excellent. I originally told people to avoid this device because the D-pad was unresponsive. But I’m changing that to a full recommendation. ClockworkPi sent out a new unit that worked perfectly. I used that unit to figure out what was broken on the original device, and it turned out that it was a bad keypad board.
From looking around online, it doesn’t look like anyone else is having that issue. So you are likely safe to assume that you won’t run into it.
With working controls, the GameShell is a delightful way to play old games. The screen could be better, but it’s not going to ruin the experience. So if you’re looking for a solid device to act as your portable retro-gaming machine, the GameShell is going to deliver what you want.
*via venturebeat.com/
The GameShell’s tool-free snap-together assembly sounds surprisingly solid for a $159 kit. I wonder if the fuzzy 320-by-240 screen would bother me enough to skip this, or if the RetroArch support makes it worth trying for my mi carta natal on the go.
I decided to explore this game during some free time. At first, I just wanted to check the design and available sections, but I ended up spending longer than expected. The interface was easy to follow, and the basic account options were clearly placed. Nothing felt overly complicated during my session, which made exploring the platform much more convenient.
Big Mumbai game download
I found this article quite engaging from the very first paragraph. The information is presented in a relaxed and understandable manner, making it easy to stay focused while reading. I liked the way the writer covered the subject without overcomplicating anything. The details feel relevant and useful, and the overall presentation is impressive. This was certainly an enjoyable article to go through.
Lottery 7 login
Keeping lottery information updated and clearly presented is helpful for regular readers. A simple layout allows visitors to find current winning numbers and review earlier draws while following lotería nacional results online.
Vacuum attachments can significantly expand the usefulness of a home cleaning machine. A crevice tool can reach narrow spaces, while an upholstery attachment can help clean sofas and chairs. Dusting brushes are useful for shelves, tables, and delicate surfaces. Some models include specialized tools for stairs, mattresses, pet hair, or car interiors. Before purchasing, homeowners should consider which areas require frequent attention. Choosing a vacuum with useful attachments can reduce the need vacuumwarehouse for separate cleaning equipment.
