WiFi Antenna Upgrade! (Better Signal )
This article is at https://forum.clockworkpi.com/t/wifi-antenna-upgrade-better-signal/5307
Hi everyone
I replaced the ceramic WiFi/BT antenna with the following (you can see the original antenna for reference):
If you want to see a quick video of the required steps, look at my insta post:
Short instructions:
disassemble the mainboard module, remove power
drill a 2mm hole on the side of the case
remove the insulation of the antenna cable to expose the core and move the shielding down (cut it before you solder, for a cleaner result)
remove the ceramic antenna, heat both sides alternating, then lift it from one side when the solder is soft with the soldering iron, then remove with pincers while heating the second pad. this is the trickiest part of the entire mod
add some solder to the pads. the idea is to sink the (insulated) core into the solder, melting the inner insulation, and soldering the insulation wires to the second pad
measure with a multi meter that the two pads are not shorted, this can happen if you apply too much heat to the insulation solder point, and it melts to the core
gently pull out the cable and close the case
reassemble
connect power and everything else, and boot to check if it still works
remove the sticker thing at the back of the antenna and glue to the case (see video)
The result is a much better WiFi signal:
The antenna comes with a selfadhesive tape so you can tape it to the case like this:
It worked :). At least for me.
Will this void your waranty? I’d say yes. Is it worth it? Totally. Is it easy to do? I think yes (if you have some experience soldering SMD parts). Would I do it again? Always (I pretend to know what I do)
Some technical details: The ceramic antenna has 50Ohm. The external has also 50Ohm. This seems to be important. The ceramic antenna has 0.5dBi. The external has 4.5-5dBi. I was told this is more than twice the range. The spec of the Wifi chip says “0-2dBi antannas”. This one still worked
Cheers, Paul
OKTK was mentioned a few times so I poked around out of curiosity, not really hunting for any particular game. The first thing that hit me was how straightforward the navigation feels—like, you don’t have to dig to figure out where stuff lives. I’m also into the way the page content is spaced out; it’s not one giant wall of text, so it’s easy to skim without your eyes glazing over. I only spent a few minutes clicking around, but it didn’t feel confusing or cluttered at all. Everything seems grouped in a way that makes sense, so you can bounce between areas without losing your place. The clean content blocks and obvious menu layout are what I noticed right…
RR88 mình mới ghé thử vì thấy mọi người nhắc hoài, kiểu vào xem giao diện ra sao thôi chứ không đào sâu gì. Cảm giác đầu tiên là trang làm khá “thoáng”, chia nội dung thành từng khối rõ ràng nên lướt xuống không bị ngợp chữ. Mình để ý họ có đoạn nói về việc hoạt động dưới sự quản lý của Isle of Man, phần này đặt ngay trong khu giới thiệu nên đọc cái là nắm ý liền. Thanh menu với mấy mục điều hướng cũng nằm chỗ dễ thấy, bấm qua lại nhanh, không phải mò. Nói chung nhìn như họ cố tình sắp xếp thông tin cho người mới vào đỡ rối, và các…
GO99 cái vụ “hốt ngay 99k” nghe đúng kiểu tiêu đề hay dùng nên mình đọc lướt thử xem trang làm có tử tế không. Vào rồi mới để ý họ đặt phần giới thiệu tổng quan khá sớm, đọc vài dòng là biết nền tảng này xuất hiện từ 2018 và họ cứ xoay quanh chuyện trải nghiệm người dùng là chính, chứ không nhồi chữ lan man. Mình vốn hay dị ứng mấy câu kiểu “top đầu” vì chỗ nào cũng tự nhận, nhưng cách trình bày ở đây lại dễ chịu, nhìn mạch lạc nên mình vẫn ngồi xem thêm một lúc. Click qua lại mấy mục cũng nhanh. Quan trọng là các khối nội dung được…
BU88 chạy ổn trên điện thoại của mình. Mở lên là thấy trang tải khá nhanh, kéo xuống đọc thông tin cũng trơn tru. Mình chỉ xem sơ bố cục với mấy khối nội dung chính thôi, kiểu chia mảng rõ ràng nên mắt không phải đảo liên tục. Nút bấm và chữ trên màn hình nhỏ vừa tay, không bị dính sát nhau nên thao tác nhẹ nhàng. Có đoạn nhắc “chơi có trách nhiệm” để ngay trong nội dung, đọc lướt cũng hiểu họ khuyên đặt giới hạn thời gian và ngân sách. Mình không ngồi thử từng trò, chủ yếu kiểm tra cảm giác chuyển mục có mượt không. Nói chung trang này làm giao diện theo…
ae888 nói về mấy trận đá gà Thomo với cái trang chủ cập nhật T10 2026 nghe thì cũng hơi “ồn” nên mình vào xem thử cho biết, kiểu vẫn nghi ngờ nhẹ xem có rõ ràng không; lướt một vòng thì thấy cách họ chia nội dung thành từng khối nhìn khá gọn, tiêu đề đặt to nên đọc nhanh vẫn bắt được ý chính, không phải dò từng đoạn dài; mình chỉ để ý đoạn giới thiệu họ nhắc nền tảng có hơn 100 lựa chọn giải trí và tách thành 5 khu vực, đọc qua là hiểu họ định dẫn người xem đi theo hướng nào, chứ mình không có ngồi soi từng mục; phần thông tin…
